Clutch Issue
Rollerskate96
Topic author - Posts: 2
Clutch Issue
Just bought a 2006 mk3. Love it but just one issue.
The clutch pedal has go to the floor to engage gears.
IT bites immediately and there is too much free play as you press the pedal. I suspect air in the system.
It's done 50000 miles.
Comments please.
Comments please.
- Has thanked: 98 times
- Been thanked: 171 times
Re: Clutch Issue
Check / topup the clutch fluid and bleed the clutch to see if it improves. You may need to set / adjust the clutch pedal free play.
_Al_
- Has thanked: 156 times
- Been thanked: 29 times
Re: Clutch Issue
That’s exactly how my rev 2 turbo was: I grew to like it.
Often clutch pedal going to the flute is cited as a C slave cylinder issue so you may want to check for leaks
Red 92 tintop JDM 3S-GTE
Blue 95 tintop JDM 3S-GTE
Mica 96 T-bar UK
Red 96 UK
Sonic Shadow 98 2GR
Mica 96 T-bar UK
Red 96 UK
Sonic Shadow 98 2GR
